VLAN statistics
Use the
statistics command in the VLAN configuration mode to enable statistics on a VLAN.
Statistics has to be manually enabled for a specific VLAN, since it is not enabled by default for VLANs.
Please note that:
- The statistics reported are not real-time statistics since they depend upon the load on the system.
- Statistics has to be manually enabled for a specific VLAN. This ensures better utilization of the statistics resources in the hardware.
- Statistics for VLANs with VE interfaces consider only the switched frames. Packets which are routed into or out of the VE interface are not counted.
- Enabling statistics on a VLAN has a heavy impact on the data traffic.
