This feature is supported only on
Extreme 8820,
SLX 9740,
SLX 9640, and
SLX 9540.
				Access global configuration
					mode.
					device# configure terminal
				Access system-monitor TM
					configuration mode.
					device(config)# system-monitor TM
				Configure the threshold interval
					to enable the monitoring of all TM deleted packets on the device.
					device(sys-mon tm)# delete-packets threshold 10
 This example configures the
					threshold of 10 TM deleted packets. A threshold of 0 disables the monitoring of
					the packets.
				(Optional) Configure the logging
					interval to monitor all TM deleted packets.
					device(sys-mon tm)# delete-packets logging-interval 100
 This step configures the
					logging interval of 100 minutes. By default, the interval is 60 minutes.
		  Configure the threshold interval to enable the monitoring of all TM discarded packets.
			 device(sys-mon tm)# discard-packets threshold 15
 This example configures the threshold of 15
					TM device-discarded packets. A threshold of 0 disables the monitoring of the
					packets.
					interval to monitor all TM discarded packets.
					device(sys-mon tm)# discard-packets logging-interval 100
		  Configure the threshold interval to enable the monitoring of all VOQ discarded packets.
			 device(sys-mon tm)# discard-voq-packets threshold 10
 This example configures the threshold of 10
					VOQ discarded packets. A threshold of 0 disables the monitoring of the packets.
					interval to monitor the VOQ discarded packets.
					device(sys-mon tm)# discard-voq-packets logging-interval 100
The following example summarizes the commands in
				this procedure.
		Use the show system monitor tm
				command to display the configuration for the deleted and discarded TM-device packets
				or the discarded VOQ discarded packets.
		The following example displays the monitoring configuration for the TM-device deleted packets.
device# show system monitor tm delete-packet
Delete packet count monitoring configuration:
Logging-interval :  60 minutes
Threshold        :  10 packets
		The following example displays the monitoring configuration for the TM-device discarded packets.
device# show system monitor tm discard-packet
Discard packet count monitoring configuration:
		The following example displays the monitoring configuration for the VOQ discarded packets.
device# show system monitor tm discard-voq-packet
Discard VOQ packet count monitoring configuration:
