An MPLS QoS EXP-to-DSCP mutation map is configured.
		  Enter global configuration mode.
device# configure terminal
		  Apply an MPLS QoS EXP-to-DSCP mutation map globally.
device(config)# qos-mpls map-apply exp-dscp expDscpMap all
		  Return to privileged exec mode
device(exp-dscp-expDscpMap)# end
		  Verify the configuration.
device# show qos-mpls maps exp-dscp
exp-dscp map 'expDscpMap'
    Exp   : 0  1  2  3  4  5  6  7
    DSCP  : 0  2  4  3  6  4  5  7
   Enabled on the following slots:
      ALL
		  Save the
			 running-config file to the
			 startup-config file.
 Apply an MPLS QoS EXP-to-DSCP mutation map globally configuration example
device(config)# end
