| Command | How to use for CoPP |
| ip icmp-fragment enable | Drop ICMP fragment packets before they are used by hackers for Denial of Service (DoS) attacks. |
| ip option disable | Discard IP packets with options before hackers send such packets to initiate DoS attacks. |
| ip access-list extended class-map match access-group policy-map | Configure rate limiting actions. For more information, see CoPP Rate Limiting. |
| ip access-list extended ip receive access-group ipv6 access-list extended ipv6 receive access-group | Permit or deny unicast and multicast control packets. For more information, see CoPP Discard and Permit for Control Packets. |
| show access-list receive | See the configuration for permit and deny rules for control plan protection. |
| show statistics access-list | See statistics for packets that meet the permit and deny rules configured for control plane protection. |
| show policy-map control-plane | See the configuration of the policy map attached to a control plane interface. |
| show interface ethernet inc rate | See whether the control plane is receiving packets at the configured rate. |
| show qos cpu info show qos cpu cfg | CPU ports that allow packets into the control plane have limited bandwidth. View the maximum CPU rates and weighted fair queue values for the various VOQ groups. |
