This topic does not apply to
SLX 9150,
SLX 9250,
Extreme 8520, and
Extreme 8720
  devices.
Buffer management consists of the following.
				- Packets arrived at ingress are stored
					in a data buffer (DB).
- A DB can be an on-chip buffer (OCB, 128
					MB) or external DRAM (up to 8 GB).
- Each OCB size is 256 B and external
					DRAM buffer size is 2 KB.
- The Virtual output queue (VOQ) holds packet
					descriptors, which are lists of buffer descriptors (BD).
- The entire packet buffer can be configured for a
					given VOQ to 1.5 GB for D cards and 2 GB for M cards.
						 Important    Specifying a
						value over 1.5 GB for a D card generates an error:  QSizeLimit LC Type -D
								ifIdx: 0x80000000, slot_id: 1, maxQueueSize: 1536.
- The DB and BD pools are managed per-license, as
					follows:
						- Avoid starving high-priority
							traffic by allocating too many resources to high-rate, low-priority
							traffic.
- Each VOQ has its own minimum
							guaranteed BD and DB (10% of the queue size). The default VOQ size is 1
							MB.
- The non-guaranteed BD and DB
							are allocated from a shared pool.
For more information, see Configure Virtual Output Queuing.
The buffer management feature is supported only on devices based on
Extreme 8820,
SLX 9740,
SLX 9640, and
SLX 9540.
