Before you begin, perform the following tasks:
Create a Policy map with the appropriate Class Map and Police configurations.
Enable IPv6 Optimised profile. Will not work with Default profile.
IPv6 egress rate limiting is only supported on SLX 9740/Extreme 8820 devices.SLX # configure terminal SLX (config) # hardware SLX (config-hardware)# profile tcam ipv6-optimised SLX (config-hardware)# end SLX (config)#
SLX (config)# ipv6 access-list extended ipv6acl seq 100 permit ipv6 4001::/64 any
SLX (config)# class-map class-map_1 SLX (config-classmap)# match access-group ipv6acl
SLX (config)# policy-map policy-map_1 SLX (config-policymap)#
SLX (config-policymap)# class class-map_1 SLX (config-policymap-class)#
SLX (config-policymap-class)# police cir 300000 eir 300000000 SLX (config-policymap-class)#
Apply to the interface.
SLX (config)# int eth 0/1 SLX (config-if-eth-0/1)# service-policy out policy-map_1
Apply to the port-channel.
SLX (config)# interface port-channel 10 SLX (config-port-channel-10)# service-policy out policy-map_1
Apply to the VE interface in the ingress direction
SLX (config)# interface ve 100 SLX (config-ve-100)# service-policy in policy-map_1
Apply to the VE interface in the egress direction
SLX (config)# interface ve 100 SLX (config-ve-100)# service-policy out policy-map_1
The following example summarizes the configuration of IPv6 rate limiting on an ethernet interface for egress traffic.
SLX(config)# ipv6 access-list extended ipv6acl SLX(conf-ipacl-ext)# seq 100 permit ipv6 4001::/64 any SLX(conf-ipacl-ext)# exit SLX(config)# class class-map_1 SLX(config-classmap)# match access-group ipv6acl SLX(config-classmap)# exit SLX(config)# policy-map policy-map_1 SLX(config-policymap)# class class-map_1 SLX(config-policymap-class)# police cir 300000 eir 300000000 SLX(config-policymap-class)# exit SLX(config-policymap)# exit SLX(config)# int eth 0/1 SLX(conf-if-eth-0/1)# service-policy out policy-map_1 SLX(conf-if-eth-0/1)# exit SLX(config)#
The following example summarizes the configuration of IPv6 rate limiting on a port-channel for egress traffic. For the configuration of the policy-map refer to the previous section.
This example summarizes the configuration of IPv6 rate limiting on a VE interface for ingress traffic.
This example summarizes the configuration of IPv6 rate limiting on a VE interface for egress traffic.
