show tm statistics device
Use these commands to display traffic management statistics for interface modules.
device# show tm statistics device interface ethernet 4/1 TM Counters: ==================================================== Ingress Counters: ---------------------------------------------- Total Ingress Pkt Count 1164304848 CPU Packet Count 0 Enque Packet Count 953260002 DeQue Packet Count 953260002 Total Discard Pkt Count 211045069 Oldest Discard Pkt Count 0 Resolved to be dropped 437190 Egress Counters: ---------------------------------------------- Unicast Pkt Count 586664425 FQP Pkt Count 586664425 Discard UC Pkt Count 0 Discard MC Pkt Count 0 MC Packet Count 0 EHP Discard Count 0
device# show tm statistics device interface ethernet 3/25 details
TM Counters:
Ingress Counters:
Total Ingress Pkt Count                  863033385
CPU Packet Count                         13
NIF Packet Count                         863033385
OAMP Packet Count                        0
OLP Packet Count                         0
Recycle Packet Count                     0
MMU IDR Packet Count                     0
Enque Packet Count                       850127673
DeQue Packet Count                       850127673
Total Discard Pkt Count                  12905725
Resolved to be dropped                   0
FDT Packet Count                         10837941
CRC Error Count                          0
Egress Counters:
Reassembly error Discard Count           21538682
    Packet UC Discard Count              10769341
    Packet MC Discard Count              0
    SOP UC Discard Count                 0
    SOP MC Discard Count                 10769341
Filter Discard Count                     10769341
    MC Pruning High Priority             0
    MC Pruning Low Priority              0
    LAG Pruning Discard Count            0
    PMF Discard Count                    0
    VLAN Member Discard Count            0
Discard MC Pkt Count                     334638
UC Pkt Count                             839289732
MC Packet Count                          10434703
FQP Pkt Count                            849724435
Editor Discard Pkt Count                 0
Editor Pkt Count                         849724435
Total Egress Pkt Count                   849724435
	 device# show tm voq-stat ingress-device ethernet 2/1 discards ---------------- Ports 1/1 - 1/36 -------------------- Dest Port | Prio | Queue | Discards ------------------------------------------------------ 3/1 | 0 | 320 | 2473804 2/4 | 0 | 224 | 1867789 4/2 | 2 | 434 | 1023452 4/8 | 4 | 487 | 920349 1/2 | 1 | 120 | 858723 1/3 | 1 | 128 | 75328 2/5 | 0 | 260 | 22234 2/6 | 0 | 268 | 5248
The entries are sorted by highest number of discards with eight entries displayed by default.device# show tm voq-stat ingress-device ethernet 2/1 discards priority 0 ---------------- Ports 1/1 - 1/36 -------------------- Dest Port | Prio | Queue | Discards ------------------------------------------------------ 3/1 | 0 | 320 | 2473804 2/4 | 0 | 224 | 1867789 2/5 | 0 | 260 | 22234 2/6 | 0 | 268 | 5248
The entries are sorted by highest number of discards with eight entries displayed by default.device# show tm voq-stat ingress-device ethernet 2/1 egress-port ethernet 2/7 priority 2 VOQ-Counters: ==================================================== Priority 2 ---------------------------------------------- EnQue Pkt Count 67404602 EnQue Bytes Count 1768413221 Total Discard Pkt Count 0 Total Discard Bytes Count 0 Current Queue Depth 0 Maximum Queue Depth since Last read 160
device# show tm voq-stat ingress-device 2/1 max-queue-depth ------------------ Ports 1/1 - 1/36 -------------------- Dest Port | Prio | Queue | Max Depth | Max Util -------------------------------------------------------- 3/1 | 0 | 320 | 1013804 | 96% 2/4 | 0 | 224 | 902789 | 86% 4/2 | 2 | 434 | 543440 | 51% 4/8 | 4 | 487 | 220349 | 21% 1/2 | 1 | 120 | 138723 | 13% 1/3 | 1 | 128 | 97328 | 9% 2/5 | 0 | 260 | 34234 | 3% 2/6 | 0 | 268 | 11723 | 1%
device# show tm voq-stat ingress-device 2/1 max-buffer-util
  Max Buffer Size |  Max Buffer Util
       6007013804 |       96%
			Use the following command to display TM statistics for Extreme 8720, Extreme 8520, SLX 9250, and SLX 9150.
device# show qos tx-queue interface ethernet 0/1
