qos remark dscp
          be enabled before applying “qos traffic class-to-DSCP map”. On L2
          switch port “qos remark dscp” cannot be disabled before removing
            “qos traffic class-to-DSCP map”.device# configure terminal
device(config)# interface ethernet 2/2
device(conf-if-eth-2/2)# qos traffic-class-cos TcDscpMap
device(conf-if-eth-2/2)# end
device# show qos maps traffic-class-dscp
          [Note: CoS = Class of Service, TC = Traffic Class, DP = Drop Precedence,DSCP = Differentiated Services Code Point]
  TC-to-DSCP Map: TcDscpMap
  In-TC:  0   1   2   3   4   5   6   7
  Out-DSCP(DP=0): 00  08  16  24  32  40  48  56
  Out-DSCP(DP=1): 00  30  16  24  32  40  48  56
  Out-DSCP(DP=2): 00  08  16  61  32  40  48  56
  Out-DSCP(DP=3): 00  08  16  24  32  40  48  56
  Enabled on the following interfaces: Eth 0/2
The following example shows how to apply a QoS traffic class-to-CoS map to an egress interface.
device# configure terminal device(config)# interface ethernet 2/2 device(conf-if-eth-2/2)# qos traffic-class-cos TcDscpMap device(conf-if-eth-2/2)# end device# show qos maps traffic-class-dscp device# copy running-config startup-config
