The following steps are only applicable to SLX 9740 and Extreme 8820.To create a CoS Mutation map:
SLX# configure terminal SLX (config)#
SLX (config)# qos map cos-mutation test-cos-mut-map-1 SLX (cos-mutation-test-cos-mut-map-1)#
SLX (cos-mutation-test-cos-mut-map-1)# map cos 1 to cos 0 SLX (cos-mutation-test-cos-mut-map-1)#
SLX (cos-mutation-test-cos-mut-map-1)# exit SLX (config)#
This is the consolidation of the above steps.
SLX# SLX# configure terminal SLX (config)# qos map cos-mutation test-cos-mut-map-1 SLX (cos-mutation-test-cos-mut-map-1)# SLX (cos-mutation-test-cos-mut-map-1)# map cos 1 to cos 0 SLX (cos-mutation-test-cos-mut-map-1)# map cos 2 to cos 5 SLX (cos-mutation-test-cos-mut-map-1)# map cos 3 to cos 1 SLX (cos-mutation-test-cos-mut-map-1)# exit SLX (config)# exit SLX#
