Precedence for ACL and Rate Limiting
		Features
	 ACL features have the following precedence:
				- OpenFlow has precedence over rACL.
- rACL has precedence over policy-based
					routing.
- Policy-based routing has precedence over
					ACL.
- ACL has precedence over VLAN rate limiting.
Rate limiting features have the following
			precedence:
				- ACL rate limiting has precedence over BUM
					storm control.
- BUM storm control has precedence over VLAN
					rate limiting and bridge domain rate limiting.
- VLAN rate limiting and bridge domain rate limiting have precedence over port
					rate limiting.
Rate limiting on an interface or port-channel has precedence over system rate
			limiting.
	 All ACL and ACL rate limiting features reside in
			one of two TCAM databases.
	 Table 1. TCAM databases and features
			 | Database | Feature |
			 | TCAM User | Layer 3 ACL |
			 | Layer 2 ACL |
			 | Layer 3 ACL rate limiting |
			 | Layer 2 ACL rate limiting |
			 | TCAM Control (Ctrl) | Layer 3 Ctrl |
			 | Layer 2 Ctrl |
			 | VLAN rate limiting |
			 | Port rate limiting |
	 For intra-database features, priority is based
			on the entry strength or ordering, such as first come, first served. For inter-database
			features, when there is a hit in both databases, the device first looks at the following
			actions:
				- For non-conflicting actions, the
					actions are merged.
- For actions with the same strength, the
					action from the User database takes precedence.
