Switch port should be configured under the interface.
QoS trust dscp is applicable for L2 Switch Port only. Trust DSCP can be enabled on physical interface after configuring Switch Port. After QoS Trust DSCP is enabled on Switch port, a user configured DSCP-to-traffic class map can be applied on the Switch Port interface.
If the IP header is present for incoming packet that is getting L2 forwarded, then traffic class is selected for this packet will be based on IP DSCP. If the IP header not present, then VLAN PCP for tagged packet, and Interface Level traffic-class config for untagged packet will be used for traffic class selection.
Follow these steps to configure an interface QoS Trust DSCP.
SLX # configure terminal SLX (config)#
SLX (config)# interface ethernet 0/2 SLX (conf-if-eth-0/2)#
SLX (conf-if-eth-0/2)# qos trust dscp SLX (conf-if-eth-0/2)#
SLX (conf-if-eth-0/2)# end SLX #
SLX #show qos interface eth 0/2
Interface Ethernet 0/2
Trust CoS : True Remark CoS : False
Trust DSCP: True Remark DSCP: False
Default TC: 0
SLX #copy running-config startup-config SLX #
This example shows the above steps in a consolidated format:
SLX # configure terminal SLX (config)# interface ethernet 0/2 SLX (conf-if-eth-0/2)# qos trust dscp SLX (conf-if-eth-0/2)# end SLX # show qos interface eth 0/2 SLX # copy running-config startup-config
