A MPLS QoS EXP-to-traffic class map is configured.
		  Enter global configuration mode.
device# configure terminal
		  Apply the MPLS QoS EXP-to-traffic class map globally.
device(config)# qos-mpls map exp-traffic-class expTcMap ALL
		  Return to privileged exec mode
device(exp-traffic-class-expTcMap)# end
		  Verify the configuration.
device#  show qos-mpls maps exp-traffic-class
exp-traffic-class map 'expTcMap'
    Exp   :    0  1  2  3  4  5  6  7
traffic-class  : 5  5  4  6  5  5  5  5
drop-precedence: 0  1  1  1  0  2  2  1
   Enabled on the following slots:
		  Save the
			 running-config file to the
			 startup-config file.
Apply a MPLS QoS EXP-to-traffic class map globally configuration example
