Use the information in the following sections to assist you as you plan your installation.
Coverage: Symmetrical coverage. 60 degree Sector: 8dBi on 6GHz
Two BLE/IoT sensor antennas
One GPS antenna
One tri-band sensor (2.4 GHz / 5 GHz / 6 GHz) antenna
Two dual-band 2.4 GHz and 5 GHz antennas
Two dual-band 5 GHz and 6 GHz antennas
One BLE/IoT sensor antenna
