AP4060 and AP4060X Installation Guide
Installation
> Troubleshoot the AP
Extreme Networks, Inc. June 01, 2026
Abstract
Preface
New in This Guide
Purchase Information
Technical Specifications
Physical Specifications
Antenna Specifications
Antenna Gain
Environmental Specifications
AP4060 Radiation Patterns
AP4060X Radiation Patterns
Ports, Connectors, and Hardware Features
Radios
Power Options
Power Profile
Accessories
LED Descriptions
Installation
Pre-Installation Tasks
Box Contents
Hardware Installation Workflow
Antenna Configuration for the Horizon Rule
Antenna Connectors
Drip Loop for Cables
Access Point Bracket Usage and Mounting Options
Wall Installations
Install the Access Point on a Flat Surface Using the AH-ACC-BKT-ASM Accessory
Install the Access Point on a Wall or Flat Surface with the KT-147407-02 Bracket
Install the Access Point Using KT-147407-02 Bracket Parts and KT-150173-01 Extension Arm
Install the Access Point on a Wall with the MBO-ART03 Bracket
Pole Installations
Install the Access Point on a Pole Using AH-ACC-STRP-MRN
Install the Access Point on a Pole Using KT-147407-02 Bracket Parts (15 Degree Tilt)
Install the Access Point on a Pole Using KT-147407-02 Bracket Parts and KT-150173-01 Extension Arm
Install the Access Point on a Pole with the MBO-ART03 and KT-147407-02 Brackets
Install the Access Point on a Unistrut Structure Using the MBO-ART03 Bracket
Adjust the MBO-ART03 Bracket Extension
Adjust the MBO-ART03 Bracket's Angular Position
Connect the ETH1 or ETH0 Cable
Connect the AP to the Network
Ground the Access Point
Secure the Access Point after Installation
Power or Pressure Washing Guidelines
Troubleshoot the AP
Micro USB Cable
Reset the AP
Regulatory and Compliance
Professional Installation Instruction
Safety Guidelines
CE Marking and European Area (EEA)
FCC Notice (Part 15 - Class B)
FCC Radiation Exposure Statement
Industry Canada Notice
Brazil Ag??ncia Nacional De Telecomunica????es (Anatel) Statement
Israel Regulatory Statement
Mexico Compliance Statement
Thailand Regulatory Statement
Taiwan Regulatory Statement
BSMI Statement - Taiwan
China Compliance Statement
United Kingdom (UK) and European Union (EU) Radiation Warning Statement
Japan (VCCI) - Voluntary Control Council for Interference Class B ITE
Extreme Networks EU Importer Address
Extreme Networks UK Address
Country of Manufacture
European Waste Electrical and Electronic Equipment (WEEE) Notice
Declaration of Conformity in Languages of the European Community
Troubleshoot the AP
Use the information in the following sections to troubleshoot your AP.
Section contents:
Micro USB Cable
Reset the AP
