Pre-Installation Tasks
Extreme Networks Access Points have been designed for quick and easy deployment. But you can make the process even easier with a little preparation.
Site Survey
Before you install your AP, do a site survey and coverage map so you have identified and addressed any potential issues.
Ask yourself the following questions:
  • What is the WLAN's purpose?
  • What applications will be used over the WLAN?
  • Who will use the WLAN?
  • What devices will be connecting to the WLAN?
  • Are there any mounting or aesthetic restrictions?
Consider the following items as you plan your deployment:
  • Capacity and coverage requirements.
  • Existing issues such as RF interference and dead zones
  • Existing networks or devices that can interfere with your network. There could be interference from floors above and below, or from outside sources such as nearby office buildings.
For more information on site surveys, see the Knowledge Base article What is Wireless Site Survey and why is it important?
Other
Perform the following tasks:
  • If you plan to use Power over Ethernet (PoE) then confirm that it meets the AP‘s requirements. See Power Profile.
  • Document the switch and ports used by the AP with LLDP protocol.
  • Confirm cables meet or exceed the required specifications.
  • Check that the AP powers up correctly.
