Use the information below when you order your AP4060.
| Part number | Description |
| AP4060-WW | Weatherized Quad Radio Wi-Fi 7 (2x2:2): 2.4GHz, 5GHz, 6GHz and dedicated sensor, Multi-Rate Port, internal antennas. Domain: World SKU |
| AP4060-WW-TAA | Weatherized Quad Radio Wi-Fi 7 (2x2:2): 2.4GHz, 5GHz, 6GHz and dedicated sensor, Multi-Rate Port, internal antennas. Domain: World SKU TAA Compliant |
| AP4060-IL | Weatherized Quad Radio Wi-Fi 7 (2x2:2): 2.4GHz, 5GHz, 6GHz and dedicated sensor, Multi-Rate Port, internal antennas. T-Bar, Incl Mt (AH-ACC-BKT-AX-TB). Domain: Israel |
Use the information below when you order your AP4060X.
| AP4060X-WW | Weatherized Quad Radio Wi-Fi 7 (2x2:2): 2.4GHz, 5GHz, 6GHz and dedicated sensor, Multi-Rate, External antennas, Domain: World SKU |
| AP4060X-WW-TAA | Weatherized Quad Radio Wi-Fi 7 (2x2:2): 2.4GHz, 5GHz, 6GHz and dedicated sensor, Multi-Rate, External antennas, Domain: World SKU TAA Compliant |
| AP4060X-EG | Weatherized Quad Radio Wi-Fi 7 (2x2:2): 2.4GHz, 5GHz, 6GHz and dedicated sensor, Multi-Rate Port, external antennas. Domain: Egypt |
