The LED status light shows the AP's operating status. A solid white means that the AP is working normally. A solid or blinking amber indicates an issue. The following table shows the LED states based on your firmware platform.
Table 1. ExtremeCloud IQ LED Activity
Status
Activity
Dark
AP is powered Off.
Solid white
The device power is On and the AP is ready to use. The device has successfully established a Control And Provisioning of Wireless Access Points (CAPWAP) connection to ExtremeCloud IQ LED Activity and is operating normally.
Solid amber
The power is On and the AP is in boot up mode, or is running without a CAPWAP connection.
Fast-blinking amber
The IQ Engine firmware is updating.
Table 2. ExtremeCloud IQ Controller Status LED Activity
Status
Activity
Dark
Power is off or the AP is taken over by the controller. Configuration pushes down to AP from Controller to turn off the LED.
Solid white
The AP is starting up or is already taken over by the controller.
Flashing fading white
Configuration pushes down to AP from controller helping the user
locate the AP by sight.
