Power Profile
The following tables shows the AP4060 and AP4060X power profiles for the radio modes. Use this information to plan for power consumption as you deploy your APs.
For all the external antennas except dipole antenna AIO-TS06360-N, there are two common orientations:
1.) Wall/pole mount facing horizontally or tilted towards the ground: This orientation allows you to use higher RF power.
2.) Any other orientation: This orientation uses lower RF power than pole mount.
For more information, see Antenna Configuration for the Horizon Rule.
Table 1. 802.3at Power Profile
AP4060 and AP4060X
Radio 1Radio 2Radio 31x1 Sensor
Mode 1
2.4G
17 dBm
5.0G - Full
18 dBm
6.0G - Full
18 dBm
1x1 Sensor
Mode 2
2.4G
17 dBm
5.0G - High
16 dBm
5.0G - Low
16 dBm
1x1 Sensor
