Hardware Installation Workflow
Access points are automatically added to your network when the DHCP and DNS prerequisites have been met. But you can save time and configure the AP before you install it with the pre-provision mode. You can revert the AP to production mode when you are ready for deployment.
Confirm that Domain Name System (DNS), Network Time Protocol (NTP), and the firewall ports are configured and available before deployment. Create a firewall rule to enable outbound traffic from Extreme Networks devices. For more information about firewalls, see Firewall Configuration Guides.
You should configure the DHCP options on your DHCP server to assign an allowed NTP server to Extreme Networks devices. Both DNS and NTP are critical for country and region detection and certificate validation. For more information about DNS and NTP, see ExtremeCloud IQ Controller Deployment Guide for Cloud deployment and Extreme Campus Controller Deployment Guide for Campus or on-premises deployment.
Important
Important
Before you install your AP, read the deployment and onboarding information in ExtremeCloud IQ Controller Deployment Guide for on-premises deployments or the Extreme Platform ONE Networking User Guide for a Cloud deployment.
Extreme Networks devices, including access points, require firmware updates to ensure optimal performance and security. During deployment, upgrade your APs to the latest firmware. For more information, see ExtremeCloud IQ Controller Deployment Guide for on-premises deployments or the Extreme Platform ONE Networking User Guide for a Cloud deployment.
Before you install your AP, read the Accessories section and confirm that you have the needed accessories. AP4060X should read the external antenna specification documentation for their antenna.
Warning
Warning
Do not stack APs on top of each other during onboarding or configuration. This may cause heat to build up between the APs, damaging the radomes and voiding the warranty.
Use the information in the following table to help you install your access point.
Table 1. Installation Work Flow
StepsActionPurpose
1
Verify the box contents.
Confirm that your AP and accessories arrived complete and undamaged.
2Install the access point based on one of the following scenarios.
Install the AP on wall:
Install the AP on pole; may need the AH-ACC-STRP-MRN:
Other:
Install the AP on a ceiling or wall, and connect the network cable. If you use Power over Ethernet (PoE), then the AP powers up.
The AP begins a discovery process to determine its own IP address and the IP address of the controller. When the discovery process is successful, the AP registers with the controller.
3AP4060X users: Install the detachable antenna. See Antenna Connectors. Read the technical specifications for your antenna here. Attach the external antenna, if you are using them.
4Onboard the AP.
Important: Extreme Cloud IQ Controller and Extreme Cloud IQ users, read Antenna Configuration for the Horizon Rule.
Onboard the AP to either ExtremeCloud IQ or ExtremeCloud IQ Controller.
5Ground the AP. (Highly recommended).Group the AP and protect the AP from lightning.
6Confirm that the LED is white. A white LED indicates that your AP has powered up and registered with the Cloud. An amber light indicates a technical issue that requires a resolution.
