Wall Installations
You have the following options to mount an AP4060 and AP4060X to a wall.
Table 1. Wall Mounting Options
Mounting AccessoryScenarioNote
Option 1: Mount to a Pole or a Wall Vertically
AH-ACC-BKT-ASM Outdoor access point stainless steel wall bracket assembly.Allows AP to mount to a wall
Option 2: Mount to a Pole with a 15-Degree Tilt
KT-147407-02 OUTDOOR HDW KIT SS HARSH ENVIRONMENTS Allows +/– 15-degree tilt – wall or pole mount
KT-150173-01 OUTDOOR AP 12 IN EXT ARM FOR MNTG KIT Allows 12 in. extension – use with KT-147407-02 for pole and/or tilt
Option 3: Mount to a Wall with > 15-Degree Tilt and Variable Extension
MBO-ART03 MBO-ART03 Articulating Mounting Bracket Allows 2 axis +/- 80-degree tilt (20-degree increments) and 10 inches extension - wall
