Antenna Connectors
It is important that you connect the antenna leads to the correct antenna port on the breakout panel. Use the following graphic and tables as a guide when you connect your antennas.
The following table maps software modes to the ports used by the mode.
Table 1. Software Mode and Corresponding Ports
Software ModeBandCorresponding PortsComment
Mode 12.4 GHz/5 GHz/6 GHz plus a tri-band sensor.Ports 1-8Used in most deployments.
Mode 25 GHz (Low)/5 GHz (High)/6 GHz plus a tri-band sensor.Ports 1-12Used for dense deployments; typically used for dual 5 GHz radios.
Mode 35 GHz/6 GHz (High)/ 6 GHz (Low) plus a tri-band sensor.Ports 1-12Used for dense deployments; typically used for dual 6 GHz radios.
Locate the antenna in the tables below and, moving across the table, connect the specified antenna lead to the port on the breakout panel.
Antenna Ports
Antenna connector ports with ports 1-4 showing 2.6 GHz/5 GHz ports, ports 5-8 showing 6 GHz ports, and ports 9-12 showing 5/6 GHz ports.
Ports 9-12 are shipped with dust covers installed. Remove the covers before connecting an antenna to the ports.
AI-TS06360 is for Internet of Things (IoT) use only. Unlike the other antennas, AI-TS06360 has one lead and it connects to the IoT port on the AP. See Hardware Ports.
Table 2. AI-TP05360
Breakout Panel
Ports
Leads
2.4/5 GHz
Port 1 1
Port 2 2
Port 33
Port 4 4
6 GHz
6 GHz alone requires ports 5 to 8; 2.4/5 GHz with 6 GHz requires ports 1 to 8.
Port 5 1
Port 6 2
Port 7 3
Port 84
Dual 5/Dual 6 GHz
Requires all 12 ports.
Port 9 1
Port 10 2
Port 11 3
Port 12 4
Note the following abbreviations: V-Pol is short for vertical polarization and H-Pol horizontal polarization.
Table 3. AI-TQ08055
Breakout Panel
Ports
Leads
2.4/5 GHz
Port 1 1/A V-Pol
Port 2 2/B H-Pol
Port 3 3/C V-Pol
Port 4 4/D H-Pol
6 GHz
Port 5 1/A V-Pol
Port 6 2/B H-Pol
Port 7 3/C V-Pol
Port 8 4/D H-Pol
Dual 5/Dual 6 GHz
Port 9 1/A V-Pol
Port 102/B H-Pol
Port 11 3/C V-Pol
Port 12 4/D H-Pol
Table 4. AIO-HQ17020
Breakout Panel
Ports
Leads
2.4/5 GHz
Port 1 1/A -45 Pol.
Port 2 2/B +45 Pol.
Port 3 3/C +45 Pol.
Port 4 4/D -45 Pol.
6 GHz
Port 51/A -45 Pol.
Port 6 2/B +45 Pol.
Port 7 3/C +45 Pol.
Port 8 4/D -45 Pol.
Dual 5/Dual 6 GHz
Port 91/A -45 Pol.
Port 10 2/B +45 Pol.
Port 113/C +45 Pol.
Port 12 4/D -45 Pol.
Table 5. AIO-DQ15021-RPSMA
Breakout Panel
Ports
Leads
2.4/5 GHz
Port 1 V-Pol
Port 2H-Pol
Port 3V-Pol
Port 4H-Pol
6 GHz
Port 5Not available
Port 6
Port 7
Port 8
Dual 5/Dual 6 GHz
Port 9(5GHz only) V-Pol
Port 10(5GHz only) 2: H-Pol
Port 11(5GHz only) V-Pol
Port 12(5GHz only) only H-Pol
Table 6. AI-TQ06120
Breakout Panel
Ports
Leads
2.4/5 GHz
Port 1 V-Pol to 1/A V-Pol
Port 2 V-Pol to 2/B H-Pol
Port 3 V-Pol to 3/C V-Pol
Port 4V-Pol to 4/D H-Pol
6 GHz
Port 5 V-Pol to 1/A V-Pol
Port 6 V-Pol to 2/B H-Pol
Port 7 V-Pol to 3/C V-Pol
Port 8V-Pol to 4/D H-Pol
Dual 5/Dual 6 GHz
Port 9V-Pol to 1/A V-Pol
Port 10 V-Pol to 2/B H-Pol
Port 11 V-Pol to 3/C V-Pol
Port 12 V-Pol to 4/D H-Pol
Table 7. AI-TH06120
Breakout Panel
Ports
Leads
2.4/5 GHz
Port 1 1/A V-Pol
Port 2 2/B H-Pol
Port 3 3/C V-Pol
Port 4 4/D H-Pol
6 GHz
Port 5 5/E V-Pol
Port 6 6/F H-Pol
Port 7 1/A V-Pol
Port 8 2/B H-Pol
Dual 5/Dual 6 GHz
Port 93/C V-Pol
Port 10 4/D H-Pol
Port 11 5/E V-Pol
Port 126/F H-Pol
Table 8. AI-TH08055
Breakout Panel
Ports
Leads
2.4/5 GHz
Port 1 1/A V-Pol
Port 22/B H-Pol
Port 3 3/C V-Pol
Port 44/D H-Pol
6 GHz
Port 5 5/E V-Pol
Port 6 6/F H-Pol
Port 7 1/A V-Pol
Port 82/B H-Pol
Dual 5/Dual 6 GHz
Port 93/C V-Pol
Port 104/D H-Pol
Port 115/E V-Pol
Port 126/F H-Pol
Table 9. AI-TH14035
Breakout Panel
Ports
Leads
2.4/5 GHz
Port 11V
Port 2 2H
Port 33V
Port 44H
6 GHz
Port 51V
Port 6 2H
Port 7 3V
Port 8 4H
Dual 5/Dual 6 GHz
Port 9 1V
Port 102H
Port 11 3V
Port 124H
