Use the information below when you order your AP. The AP5022 ships with the AH-ACC-BKT-AX-TB bracket.
6 GHz indoor operation is country dependent.For AP5022FX units outside the US and Canada, the internal 6 GHz radio is enabled to support Low Power Indoor (LPI) operation
| SKU | Description |
| AP5022-WW | Indoor Quad Radio Wi-Fi 7 (4x4:4): 2.4 GHz, 5 GHz, 6 GHz and dedicated full time sensor, Dual IOT, Dual 5 GHz, Dual 6 GHz, Multi-Rate Port, Internal antennas. T-Bar, Incl Mt (AH-ACC-BKT-AX-TB). Domain: World SKU |
| AP5022-WW-TAA | Indoor Quad Radio Wi-Fi 7 (4x4:4): 2.4 GHz, 5 GHz, 6 GHz and dedicated full time sensor, Dual IOT, Dual 5 GHz, Dual 6 GHz, Multi-Rate Port, Internal antennas. T-Bar, Incl Mt (AH-ACC-BKT-AX-TB). Domain: World SKU TAA Compliant |
| AP5022S6D-WW | Indoor Quad Radio Wi-Fi 7 (4x4:4): 2.4 GHz, 5 GHz, 6 GHz and dedicated full time sensor, Dual IOT, Dual 5 GHz, Dual 6 GHz, Multi-Rate Port, Internal 60 Degree directional antennas. T-Bar, Incl Mt (AH-ACC-BKT-AX-TB). Domain: World SKU |
| AP5022FX-WW | Indoor Quad Radio Wi-Fi 7 (4x4:4): 2.4 GHz, 5 GHz, 6 GHz and dedicated full time sensor, Dual IOT, Dual 5 GHz, Dual 6 GHz, Multi-Rate Port, Extended Temp, External antennas. T-Bar, Incl Mt (AH-ACC-BKT-AX-TB). Domain: World SKU |
