Technical Specifications
The AP5022, AP5022S6D and AP5022FX support both 802.3at PoE and 802.3bt PoE. It is supported on the following platforms:
  • ExtremeCloud IQ
  • ExtremeCloud IQ Controller.
For more information about the technical specifications, see the Data Sheets found here.
South Korea, Mexico, Taiwan, and Brazil require the use of Cat6 shielded cable.
