Use the ACC-CBL-BRKOUT-12RPSMA breakout cable when you need to connect several external antennas to the AP5022FX. The cable has a 12-port Reverse Polarity SMA (RP-SMA) connector, LMR-100 cabling, and is 9 in. long. The breakout cable may be installed on a pole or a wall.
The ACC-CBL-BRKOUT-12RPSMA breakout cable supports the AP5022FX only. One breakout cable is included in the box.
For pole installations, mount the breakout cable facing downwards and install a wire tie across the tab and around the pole.
For wall installations, fasten the breakout cable to a wall with a M3.5 screw and wall anchor when appropriate.
Breakout Cable
Call Out
Description
1
M3.5 screw hole for connecting breakout cable to wall.
2
Tab for connecting breakout cable to pole.
3
Breakout cable port.
Locate the breakout cable port.
The port is on the side opposite to the Ethernet ports.
Insert the 12 port connector into the breakout cable port.
