Physical Dimensions
The AP5022, AP5022S6D and AP5022FX have following dimensions and weight:
Table 1. AP5022, AP5022S6D and AP5022FX Physical Dimensions
ModelDimensionsWeight
AP5022258mm × 258mm × 46mm (10.16 in. × 10.16 in. × 1.81 in.)1.62 kg (3.57 lbs.)
AP5022S6D
258mm × 258mm × 46mm (10.16 in.× 10.16 in. × 1.81 in.)1.53 kg (3.37 lbs.)
AP5022FX
258mm × 265mm × 46mm (10.16 in. × 10.43 in. × 1.81 in.)1.53 kg (3.37 lbs.)
