Cleaning Guidelines
You can clean your APs with the following solutions:
  • Hydrogen peroxide (a 3% solution)
  • Chlorine bleach
  • Sodium hypochlorite (a 0.05% solution)
  • Ethyl alcohol (a 75% solution)
  • Isopropyl alcohol (a 75% solution)
  • White vinegar
  • Sporicidal (peracetic acid; a 0.5% solution)
  • Water
  • Baking soda (a 3:1 solution)
  • Non-abrasive soap
Do not wash or immerse the AP in a liquid. You will damage the device and void the warranty. Instead, you can wipe the plastic housing - also called the radome - with a damp cloth. But you must avoid the ports and connectors.
Do not power wash the AP.
