If your switch does not come with an installed power supply, you can install one or two power supplies. All installed power supplies must blow air in the same direction and must match the airflow direction of the installed fan modules.
Installed power supplies can be AC, DC, or a combination of AC and DCFor installation instructions, see Replace Power Supplies.
