8820 Series Installation Guide
> Remove and Replace Components
Extreme Networks, Inc. April 01, 2026
Introduction to the Extreme 8820 Installation Guide
New in this Guide
Extreme 8820 Overview
Extreme 8820-40C Switch Features
Extreme 8820-80C Switch Features
Manage Your Switch
Fan Modules for Use with Your Switch
Extreme 8820-40C Fan Modules
Extreme 8820-80C Fan Modules
Power Supplies for Use with Your Switch
1600 W AC Power Supplies
1600 W DC Power Supplies
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Attach Your Switch to a Rack or Cabinet
Install Optional Components
Install Internal Power Supplies
Turn on the Switch
Login for the First Time on Extreme OS ONE
Login for the First Time on Extreme SLX-OS
Monitor the Switch
System Status LEDs
RJ-45 Management Port LEDs
QSFP28 Port LEDs
Remove a Switch from a Rack
Remove a Switch from a Four-Post Rack
Remove a Switch from a Two-Post Rack
Replace Power Supplies
Power Supply Airflow Direction Requirements
Replace a Power Supply
Connect a DC Power Supply to a DC Power Source
Replace Fan Modules
Fan Airflow Direction Requirements
Replace a Fan Module
Change Airflow Direction
Technical Specifications
Extreme 8820 Technical Specifications
Fan and Acoustic Noise
Power Specifications
Mean Time Between Failures (MTBF)
CPU, Memory
1600 W Power Supply Technical Specifications
Standards
Environmental Standards
Use the information in the following topics to remove or replace components.
Section contents:
Replace Fan Modules
