Extreme 8820 Technical Specifications
External Interfaces contains external interfaces and weights and dimensions information for Extreme 8820 switches.
Table 1. External Interfaces
ItemExtreme 8820-80CExtreme 8820-40C
Maximum 100 GbE/40 GbE ports8040
Maximum 10/25 GbE144 ports in breakout mode (36x4)72 ports in breakout mode (18x4)
Switch fabric capacity (data rate, full duplex)8.0Tbps in each direction (front panel ports, 80x100Gbps)4.0 Tbps in each direction (front panel ports, 40x100Gbps)
Forwarding capacity (data rate, full duplex)4000Mpps (packet size=284B)2000Mpps (packet size=284B)
AirflowFront to back or back to front (orderable option)Front to back or back to front (orderable option)
Fan module slots4 (3+ 1 redundancy)6 (5+ 1 redundancy)
Maximum AC power supply rating1600 W1600 W
Power Supplies Modular1600W AC/DC power supply (up to four PSUs)1600W AC/DC power supply (up to two PSUs)
Height3.41in / 8.66 cm1.7in / 4.31 cm
Width17.72in / 45.00 cm17.72in / 45.00 cm
Depth chassis only without cable management or fan handles
25.2in / 64.00 cm
25.2in / 64.00 cm
Weight Chassis4PS, 4 fans: 58.46 lb / 26.52 kg2PS, 6 fans: 29.98 lb / 13.60 kg
Weight Chassis
4PS, 4 fans, rack mount kit (4 post): 64.99 lb / 29.48 kg
2PS, 6 fans, rack mount kit (4 post): 36.24 lb / 16.44 kg
Weight Empty chassis (no PS, no fans)
45.46 lb, 20.62 kg
Fan: 0.71 lb, 0.32 kg
PS: 2.54 lb, 1.15 kg
23.28 lb, 10.56 kg
Fan: 0.27 lb, 0.13 kg
Port typeQSFP28 Port Configs: 80x100GbE, 80x40GbE, 144x25GbE, 144x10GbEQSFP28 Port Configs: 40x100GbE, 40x40GbE, 72x25GbE, 72x10GbE
Packet buffers per switch16 GB8 GB
Operating Conditions
Operating temperature and operating altitude for airflow front to back: 0°C (32°F) to 40°C (104°F) up to 1800m (6000 ft)
Operating temperature and operating altitude for airflow back to front: 0°C (32°F) to 25°C (77°F) up to 1800 m (6000 ft)
Storage temperature: -40°C to 70°C (-40°F to 158°F)
Operating Relative Humidity: 5% to 95% (non-condensing)
Table 2. Weights and Dimensions of Accessories
AccessoryWeightDimensions
1600 W AC PSU1.15 kg (2.54 lb)Height: 8.64 cm (3.4 in.)
Width: 4.01 cm (1.58 in.)
Length: 24 cm (9.45 in.)
1600 W DC PSUHeight: 8.64 cm (3.4 in.)
Length: 25.5 cm (10.04 in.)
XN-FAN-003-F: Fan unit, front-to-back or XN-FAN-003-R: Fan Unit back-to-front
0.13 kg (0.27 lb)Height: 4.01 cm (1.58 in.)
Length: 13.99 cm (5.51 in.)
XN-FAN-004-F: Fan unit, front-to-back or XN-FAN-004-R: Fan Unit back-to-front
0.32 kg (0.71 lb)Height: 5.99 cm (2.36 in.)
Width: 4.01 cm (2.36 in.)
Length: 15.49 cm (6.1 in.)
XN-4P-RKMT302 - Four-post rack mount kit for Extreme 8820-40C (included with switch)
2.66 kg (5.87 lb)Height: 5.00 cm (1.97 in)
Width: 7.01 cm (2.76 in)
Length: 72.00 cm (28.35 in)
XN-4P-RKMT301 - Four-post rack mount kit for Extreme 8820-80C (included with switch)2.9 kg (6.39 lb)
XN-2P-RKMT299 - Two-post rack mount kit for Extreme 8820-40C (ordered separately)
0.45 kg (0.99 lb)Height: 4.2 cm (1.65 in)
Width: 2.4 cm (0.93 in)
Length: 12.5 cm (4.92 in)
XN-2P-RKMT300 - Two-post rack mount kit for Extreme 8820-80C (ordered separately)
0.70 kg (1.54 lb)Height: 8.99 cm (3.54 in)
Width: 10.16 cm (4.00 in)
Length: 13.00 cm (5.12 in)
Console Cables
Description
XN-RJ45-DB9-CONSOLE-CBLRJ45 to DB9 Console cable (6ft)
XN-RJ45-USBA-CONSOLE-CBLRJ45 to USBA Console cable (6ft)*
XN-RJ45-USBC-CONSOLE-CBLRJ45 to USBC Console cable (6ft)*
* The cable might require a FTDI software driver on some operating systems.
