Power Specifications
This topic describes power supply specifications, power consumption, and heat dissipation. Refer to the Extreme 8820 Data Sheet for up-to-date information.
Extreme 8820 1600 W AC power supply:
Part # XN-ACPWR-1600W-F (front-to-back):
AC Input: 100-120/200-240 VAC, 50/60 Hz
Part # XN-ACPWR-1600W-R (back-to-front):
AC Input: 200-240 VAC, 50/60 Hz
7A max. for PSU FSG059 for each PSU for Extreme 8820-40C
4A max. for PSU FSG059 and FSE023 for each PSU for Extreme 8820-40C; for Extreme 8820-80C, min. 2 PSUs provided.
PSU Input Socket: IEC 320 C14
Power cord input plug: IEC 320 C13
1600 W DC power supply:
Part # XN-DCPWR-1600W-F (front-to-back)
Part # XN-DCPWR-1600W-R (back-to-front)
DC Input: +/- 48VDC 15A Max (for PSU FSK010) for each PSU for Extreme 8820-40C
+/- 48VDC 15A Max (for PSU FSK010) for each PSU, min. x2 for Extreme 8820-80C
Power and Heat Dissipation
Extreme 8820-80C Maximum Heat Dissipation (BTU/hr) (Fans high, all ports 100% traffic, 4 PSU)Extreme 8820-80C Maximum Power Dissipation (Watts) (Fans high, all ports 100% traffic, 4 PSU)
6592.26 BTU/hr 1932
Extreme 8820·40C Maximum Heat Dissipation (BTU/hr) (Fans high, all ports 100% traffic, 2 PSU)Extreme 8820·40C Maximum Power Dissipation (Watts) (Fans high, all ports 100% traffic, 2 PSU)
3524.74 BTU/hr1033
