Manage Your Switch
Each switch can be flexibly managed though the CLI for manual configuration, or through REST or NETCONF/YANG APIs, or standard SNMP applications.
Connect to Your Switch
You can use the following methods to connect to the switch.
- RJ45 serial console port
- Attach an RJ45 to DB9 adapter cable to the RJ45 serial console port on the switch to connect a terminal to manage the switch locally. The RJ45 serial console port is located on the front panel of the switch.
- Ethernet management port
- Attach an Ethernet cable to an Ethernet management port to connect the system to an out-of-band management network to manage the switch. The 8820-40C switch has one Ethernet management port. The 8820-80C switch has dual management ports. The primary port, MGMT1, is directly connected to the CPU. The secondary port, MGMT2, is connected to a switch so that the CPU and BMC can share the port. An Ethernet management port provides dedicated remote access to the switch using TCP/IP. The switch uses an Ethernet management port only for host operation, not for switching or routing.
Alternatively, attach an Ethernet cable directly to the Ethernet management port and a laptop to view and locally manage the switch configuration.
- The Ethernet management port is located on the front panel of the switch. It supports 10/100/1000 Mbps speeds.
For switch connection details, see Connect to a Management Console.
Configure and Operate Your Switch
The switch supports flexible configuration and operation through the following methods.
- Web-based GUI or generic command-line interface (CLI)
- The command line interface (CLI) is a powerful tool for managing and configuring switches and network settings. The CLI interface can be accessed through the web-based GUI, or through Telnet, Secure Shell (SSH2), or SNMP using an SNMP manager. The web server must be enabled in the operating system on the switch in order to use the web-based GUI. For more information on Extreme OS ONE, see the Extreme OS ONE Switching Management Configuration Guide and the Extreme OS ONE Switching Command Reference for your version of the Extreme OS ONE operating system. For more information on Extreme SLX-OS, see the Extreme SLX-OS Management Configuration Guide for your version of the Extreme SLX-OS operating system.
- REST API
- The REST API (Representational State Transfer Application Programming Interface) can be used for managing and configuring switches through a programmatic interface. It is HTTP-based and allows clients to interact with the server and operational data. It can be used for out-of-band and in-band management through an Ethernet connection. The REST API can be accessed through the RESTCONF interface after it has been enabled in the operating system. Refer to the REST API guide for the switch operating system for more information.
- NETCONF Interface
- NETCONF (Network Configuration Protocol) is a protocol used for managing and configuring network devices. NETCONF APIs allow for programmatic access to the switch configuration and operational data. It can be used for in-band management through an Ethernet connection. NETCONF must be enabled in the operating system on the switch and can be accessed using a NETCONF client. Refer to the NETCONF API guide for the switch operating system for more information.
- Lights Out Management (LOM)
- The switch contains a baseboard management controller (BMC) for lights-out management (LOM) for remote operations such as reboots, shutdowns, and out-of-band troubleshooting.
- Simple Network Management Protocol (SNMP)
- SNMP provides facilities to manage and monitor network resources using agents, managers, the SNMP protocol, and Management Information Bases (MIBs). SNMP must be configured on the switch and accessed through an SNMP manager. For more information on Extreme OS ONE, see the Extreme OS ONE Switching Management Configuration Guide and the Extreme OS ONE Switching Command Reference for your version of the Extreme OS ONE operating system. For more information on Extreme SLX-OS, see the Extreme SLX-OS Management Configuration Guide for your version of the Extreme SLX-OS operating system.
