configure mirror control_index
configure mirror control_index [ add | delete ] mirror_name
Description
Adds or deletes existing mirrors to a mirror MIB instance (specified by a control index) .
Syntax Description
mirror_name Specifies a specific mirror name to add to or delete from a mirror MIB instance.
control_index
Mirror destination control index (1–4).
Also known as: etsysMirrorDestinationControlIndex. Each comprises a group of mirror names.
add Specifies adding a mirror name to group referenced by a control index.
delete Specifies deleting a mirror name from a group referenced by a control index.
Default
N/A.
Usage Guidelines
To use policy-based mirroring, you need a mirror MIB instance (designated by a control index) with one or more associated mirrors to apply mirrors to a policy profile.
Only mirrors with a single 'to' port or remote-ip can be applied to a mirror MIB instance.
The following example adds existing mirror "mirror1" to mirror MIB instance with control index "2":
configure mirror 2 add mirror1
This command was first available in ExtremeXOS 30.2.
Platform Availability
This command is available on all platforms.
