Unconfigures the disconnect precedence setting and returns the switch to the default disconnect precedence value of deny port.
Deny-port.
You configure this parameter for the entire switch; you cannot configure this per slot or per port.
Unconfigures the This command is available on the X465 series switch. disconnect precedence previously set for the switch and returns the disconnect precedence to the default value of deny port. Deny port denies power to the next PD that requests inline power from the slot when the inline power budget for the switch or slot is reached, regardless of the inline power port priority.
The following command resets the switch to the PoE disconnect precedence value, which is deny port:
unconfigure inline-power disconnect-precedence
This command was first available in ExtremeXOS 11.1.
This command is available on the PoE devices listed in Extreme Networks PoE Devices.
