Power cycles the specified ports.
| port_list | Specifies one or more ports or slots and ports for which power is to be reset. |
N/A.
This command power cycles the specified ports. Ports are immediately disabled and then re-enabled, allowing remote PDs to be power-cycled.
This command affects only inline power; it does not affect network connectivity for the port(s).
The following command resets power for port 4 on a switch:
reset inline-power ports 4
This command was first available in ExtremeXOS 11.1.
This command is available on the This command is available on the X465 series switch. devices listed in Extreme Networks PoE Devices.
