unconfigure inline-power classification
unconfigure inline-power classification ports port_list
Description
This command configures This command is available on the X465 series switch. port-level classification power-up mode for Extreme Networks PoE devices that do not support 802.3bt when connecting to switches with 60W/90W PoE ports. ExtremeSwitching platforms support per-port basis configuration.
Syntax Description
classification Classification power-up mode.
ports Specifies the port.
port_list Port list separated by a comma or - .
Default
N/A.
Usage Guidelines
This command restores port-level classification power-up mode to default based on port type.
# show inline-power configuration ports 20-26
Port   Config    Operator Limit  Priority   Detection                   Classification    Label
20     Enabled   60000 mW        Low        802.3af-only                802.3pre-bt       N
21     Enabled   60000 mW        Low        802.3af-only                802.3bt-type3     N
22     Enabled   60000 mW        Low        802.3af-only                802.3bt-type3     N
23     Enabled   45000 mW        Low        2-point legacy-and-802.3af  802.3bt-type3     N
24     Enabled   60000 mW        Low        802.3af-only                802.3at           N      x435-port10
25     Enabled   90000 mW        Low        4-point legacy-and-802.3af  802.3pre-bt       N
26     Enabled   90000 mW        Low        802.3af-only                802.3bt-type3     N
This command was first available in ExtremeXOS 31.3.
Platform Availability
This command is available on all platforms.
