enable inline-power slot
enable inline-power [fast | perpetual] slot slot
Description
Enables This command is available on the X465 series switch. power, and fast and perpetual PoE power to the specified node (slot) on SummitStacks.
Syntax Description
slot Enables inline power to specified slot.
fast Deliver PoE power to devices at the time of switch power on without waiting for boot up based on last saved PoE state. The default is disabled.
perpetual Preserves PoE power delivery to devices during reboot. Perpetual PoE is a switch-wide setting. The default is disabled.
Default
By default:
  • PoE is enabled.
  • Fast PoE is disabled.
  • Perpetual PoE is disabled.
Usage Guidelines
Disabling inline power to a slot immediately removes power to any connected PDs. By default, inline power provided to all slots is enabled. Additionally, you can opt to deliver PoE power to devices at the time of switch power on without waiting for boot up (fast PoE) based on last saved PoE state. You can also elect to preserve PoE power delivery to devices during reboot (perpetual PoE). The default for both PoE options is disabled.
To deliver inline power to slots, you must reserve power for that slot using the configure inline-power budget command. By default, each PoE module has 50 W of power reserved for inline power.
Disabling inline power using the disable inline-power command does not affect the data traffic traversing the slot. And, disabling the slot using the disable slot command does not affect the inline power supplied to the slot.
If you do not specify a slot number, the command operates on all active nodes in the stack. This command operates only on nodes in the active topology.
The following command makes inline power available to slot 3:
# enable inline-power slot 3
The following example turns on perpetual PoE to slot 3:
# enable inline-power perpetual slot 3
This command was first available in ExtremeXOS 11.1.
The fast and perpetual PoE options were added in ExtremeXOS 30.3.
Platform Availability
This command is available on SummitStack when the stack contains switches listed in Extreme Networks PoE Devices.
The fast and perpetual options are only available on the ExtremeSwitching X465 and X435 series switches.
