Creates a "control group" mirror referenced by a unique control index.
| control_index | Mirror destination control index in the form of a number 1–4. Also know as. etsysMirrorDestinationControlIndex. Each comprises a group of mirror names. |
N/A.
You can apply mirrors to policy profile rules by using a "control group" mirror referenced by a unique control index number (1–4). These control group mirrors are etsysMirrorDestinationControlEntry entries in the ENTERASYS-MIRROR-CONFIG-MIB (Mirror MIB). A Mirror MIB instance (designated by a control index) can be associated with up to four "physical" mirrors, each being one destination port (or tunnel). To create physical mirrors, use the command create mirror mirror_name {to [port port | port-list port_list loopback-port port] { remote-tag rtag } | remote-ip remote_ip_address {{ vr } {vr_name } {from [ source_ip_address | auto-source-ip]}{ping-check [on | off]} priority priority_value ]} {description mirror-desc}.
The following example creates a control group mirror with control index number of "1":
# create mirror 1
This command was first available in ExtremeXOS 30.2.
This command is available on all platforms.
