disable mirror control_index
disable mirror control_index {mirror mirror_name}
Description
Disables a Mirror MIB instance or the assigned instance to an existing mirror.
Syntax Description
control_index Selects the Mirror MIB instance to disable. Range is 1 through 4.
mirror Designates specifying a mirror name associated within the specified control index.
mirror_name Specifies the mirror name associated within the specified control index.
Default
Disabled.
Usage Guidelines
Specifying a mirror name only disables that mirror within the Mirror MIB group (control index).
The following example disables Mirror MIB specified by control index "1":
# disable mirror 1
The following example disables the mirror named "m1" within the Mirror MIB specified by control index "1":
# disable 1 mirror m1
This command was first available in ExtremeXOS 30.2.
Platform Availability
This command is available on all platforms.
