enable mirror control_index
enable mirror control_index {mirror mirror_name}
Description
Enables a Mirror MIB instance or the assigned instance to an existing mirror.
Syntax Description
control_index Selects the Mirror MIB instance to enable. Range is 1 through 4.
mirror Designates specifying a mirror name associated within the specified control index.
mirror_name Specifies the mirror name associated within the specified control index.
Default
Disabled.
Usage Guidelines
Specifying a mirror name only enables that mirror within the Mirror MIB group (control index).
The following example enables Mirror MIB specified by control index "1":
# enable mirror 1
The following example enables the mirror named "m1" within the Mirror MIB specified by control index "1":
# enable 1 mirror m1
This command was first available in ExtremeXOS 30.2.
Platform Availability
This command is available on all platforms.
