show inline-power info ports
show inline-power info {detail} ports {port_list}
Description
Displays inline power information for the specified ports.
Syntax Description
port_list Specifies one or more ports. If you do not specify ports, information for all ports appears.
Default
N/A.
Usage Guidelines
Ports in the denied or faulted state periodically display the searching state as the hardware retests the PD state.
You can use this command to generate a summary report or a detailed report.
Summary output displays the following inline power information for the specified ports:
  • State—Displays the port power state:
    • Disabled.
    • Searching.
    • Delivering.
    • Faulted.
    • Disconnected.
    • Other.
    • Denied.
  • PD‘s power class—Displays the class type of the connected PD:
    • “-----”: disabled or searching.
    • “class0”: class 0 device.
    • “class1”: class 1 device.
    • “class2”: class 2 device.
    • “class3”: class 3 device.
    • “class4”: class 4 device.
    • "class5": class 5 device.
    • "class6": class 6 device.
    • "class7": class 7 device.
    • "class8": class 8 device.
  • Volts—Displays the measured voltage. A value from 0 to 2 is valid for ports that are in a searching state.
  • Curr—Displays the measured current, in milliamperes, drawn by the PD.
  • Power—Displays the measured power, in watts, supplied to the PD.
  • Fault—Displays the fault value:
    • None.
    • UV/OV fault.
    • UV/OV spike.
    • Over current.
    • Overload.
    • Undefined.
    • Underload.
    • HW fault.
    • Discovery resistance fail.
    • Operator limit violation.
    • Disconnect.
    • Discovery resistance, A2D failure.
    • Classify, A2D failure.
    • Sample, A2D failure.
    • Device fault, A2D failure.
    • Force on error.
The detail command lists all inline power information for the selected ports.
Detail output displays the following information:
  • Configured Admin State—Displays the port‘s configured state; Enabled or Disabled.
  • Inline Power State—Displays the port power state.
  • MIB Detect Status—Displays the port state as reported by SNMP; valid values are as follows:
    • disabled
    • searching
    • delivering
    • fault
    • test
    • otherFault
    • denyLowPriority
  • Label—Displays the port‘s configured label.
  • Operator Limit—Displays the port‘s configured operator limit value.
  • PD Class—Displays the class type of connected PD:
  • Max Allowed Power—Displays the amount of maximum allowed power for a device of this class.
  • Measured Power—Displays the measured power, in watts, supplied to the PD.
  • Line Voltage—Displays the measured voltage. A value from 0 to 2 is valid for ports in a searching state.
  • Current—Displays the measured current, in milliamperes, drawn by the PD.
  • Fault Status—Displays the fault value.
  • Detailed Status
  • Priority
  • Power Up Status—2-pair or 4-pair, 15W–90W
  • Powered Channels—primary channel, alternative channel, or both
  • Detection
The following command displays summary inline power information for ports 1 to 3 on a switch:
show inline-power info ports 1-3
The following is sample output from this command:
Port  State         Class      Volts   Curr    Power     Fault
(mA)   (Watts)
1   delivering    class3     48.3    192      9.300    None
2   delivering    class3     48.3    192      9.300    None
3   searching     ------      0.0      0      0.0      None
The following command displays detail inline power information for port 1 on slot 3:
show inline-power info detail port 3:1
Port 3:1
Configured Admin State: enabled
Inline Power State    : delivering
MIB Detect Status     : delivering
Label                 :
Operator Limit        : 16800 milliwatts
PD Class              : class3
Max Allowed Power     : 15.400 W
Measured Power        : 9.400 W
Line Voltage          : 48.3 Volts
Current               : 193 mA
Fault Status          : None
Detailed Status       :
The following command displays detail inline power information for port 27:
# show inline-power info detail ports 27
Port 27
Label                 :
Operator Limit        : 90000 milliwatts
PD Class              : class8
Max Allowed Power     : 90.0 W
Measured Power        : 33.300 W
Line Voltage          : 53.7 Volts
Current               : 621 mA
Fault Status          : None
Detailed Status       : Delivering power to IEEE PD
Priority              : low
Power Up Status       : 4-pair 60W
Powered Channels      : Primary and Alternative
Detection             : 802.3af-only
The following command displays detail inline power information with class-based configured for port 1:
# show inline-power info detail ports 1
The following is sample output for this command (lines 7 and 9):
Port 1
Label                 :
Operator Limit        : class-based (97000 milliwatts when not class-based)
PD Class              : class6
Max Allowed Power     : 60.0 W
Measured Power        : 49.800 W
Line Voltage          : 54.2 Volts
Current               : 919 mA
Fault Status          : None
Priority              : low
Power Up Status       : 4-pair 90W
This command was first available in ExtremeXOS 11.1.
PD classes 7 and 8, and power up status and powered channels information for ExtremeSwitching X465 PoE switches with 60W ('u') and 90W ('w') ports was added in ExtremeXOS 30.2.
class-based information was added in ExtremeXOS 32.3.
Platform Availability
This command is available on the This command is available on the X465 series switch. devices listed in Extreme Networks PoE Devices.
