enable clear-flow
enable clear-flow
Description
Enable the CLEAR-Flow agent.
Syntax Description
Default
CLEAR-Flow is disabled by default.
Usage Guidelines
When the CLEAR-Flow agent is enabled, sampling begins and actions are taken based on the CLEAR-Flow rules that are configured on the switch.
The following example enables CLEAR-Flow on the switch:
# enable clear-flow
This command was first available in ExtremeXOS 11.1.
Platform Availability
This command is available on X465 and X695 series switches.
