Configures the SNMPv3 Engine Boots value.
| (1-2147483647) | Specifies the value of engine boots. |
N/A.
Use this command if the Engine Boots value needs to be explicitly configured. Engine Boots and Engine Time will be reset to one (1) if the Engine ID is changed. Engine Boots can be set to any desired value, but will latch on its maximum, 2147483647.
The following command configures Engine Boots to 4096:
configure snmpv3 engine-boots 4096
This command is available on all platforms.
