replace
Selects an existing device by its MAC address or hostname and replaces it with a new device having a different MAC address. Internally, a new device is created with the new MAC address. The old device‘s configuration is copied to the new device, and then removed from the controller‘s configuration (i.e., the old device‘s configuration is no longer staged on the controller).
  • Access Points — AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8432, AP8533
  • Wireless Controller — RFS4010
  • Service Platforms — NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
replace device [<MAC-ADDRESS>|<HOSTNAME>] <NEW-MAC-ADDRESS>
Parameters
replace-device Replaces an existing device with a new device, such that the old device‘s configuration is copied on to the new device
[<MAC-ADDRESS>| <HOSTNAME>] Identifies the device to replace by its MAC address or hostname
  • <MAC-ADDRESS> – Identifies the device to replace by its MAC address. Specify the device‘s existing MAC address.
  • <HOSTNAME> – Identifies the device to replace by its hostname. Specify the device‘s hostname.
<NEW-MAC-ADDRESS> Specifies the new device‘s MAC address. Both the new and old devices should of the same model type.
rfs4000-882A17(config)#replace device ap7532-4BF364 ?
  AA-BB-CC-DD-EE-FF New device MAC address
rfs4000-882A17(config)#replace device ap7532-4BF364 00-15-0F-BB-98-30
The following example shows an existing AP 7502 (MAC: DD-AA-BB-88-12-43) configuration staged on a VX 9000 controller:
VX9000-NOC-DE9D(config-device-DD-AA-BB-88-12-43)#show context
ap7502 DD-AA-BB-88-12-43
 use profile default-ap7502
 use rf-domain default
 hostname ap7502-881243
 interface radio1
  wlan theMOZART bss 1 primary
 interface radio2
 interface ge1
  switchport mode access
  switchport access vlan 1
 controller host 12.12.12.2
The following example shows AP 7502 (MAC: DD-AA-BB-88-12-43) replaced by another vAP 7502 having MAC address 11-22-33-44-55-66:
Note that the new AP 7502 device has the same configuration as the old AP 7502 device. The HOSTNAME remains the same. Consequently, objects that refer to this particular hostname need not be updated. For example, an hostname alias identifying this particular device, and TLOs using this alias, such as IP/MAC ACLs, remain unchanged.
VX9000-NOC-DE9D(config)#replace device DD-AA-BB-88-12-43 11-22-33-44-55-66
VX9000-NOC-DE9D(config)#ap7502 11-22-33-44-55-66
VX9000-NOC-DE9D(config-device-11-22-33-44-55-66)#show context
 interface radio1
 interface radio2
 interface ge1
