router-id
Configures the tunnel's local router ID
  • Access Points — AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8432, AP8533
  • Wireless Controller — RFS4010
  • Service Platforms — NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
router-id [<1-4294967295>|<IP>]
Parameters
Configures the tunnel's local router ID in one of the following formats:
  • <1-4294967295> – Router ID in the number format (from1- 4294967295)
  • <IP> – Router ID in IP address format (A.B.C.D)
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#router-id 2000
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#show context
 l2tpv3 tunnel Tunnel1
  peer 2 hostname tunnel1peer1 udp port 100
  router-id 2000
  establishment-criteria cluster-master
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1))#
Related Commands
no
Removes the tunnel's router ID
