ip-address-type
Advertises the IP address type used in this hotspot. This information is returned in response to ANQP queries.
  • Access Points — AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8432, AP8533
  • Wireless Controller — RFS4010
  • Service Platforms — NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
ip-address-type [ipv4|ipv6]
ip-address-type ipv4 [double-nat|not-available|port-restricted|port-restricted-double-nat|
port-restricted-single-nat|public|single-nat|unknown]
ip-address-type ipv6 [available|not-available|unknown]
Parameters
ip-address-type ipv4 Configures the IPv4 address type availability information
double-nat Specifies double NATed private IPv4 address is available
not-available Specifies IPv4 address is not available
port-restricted Specifies port-restricted IPV4 address is available
port-restricted-double-nat Specifies port-restricted IPv4 address and double NATed IPv4 address is available
port-restricted-single-nat Specifies port-restricted IPv4 address and single NATed IPv4 address is available
public Specifies public IPv4 address is available
single-nat Specifies single NATed IPv4 address is available
unknown Specifies no information configured regarding the IPv4 address availability
ip-address-type ipv6 Configures the IPv6 address type availability information
available
Specifies IPv6 address is available
not-available
Specifies IPv6 address is not available
unknown
Specifies no information configured regarding the IPv6 address availability
rfs4000-229D58(config-passpoint-policy-test)#ip-address-type ipv6 available
rfs4000-229D58(config-passpoint-policy-test)#show context
hotspot2-policy test
 access-network-type chargeable-public
 connection-capability ip-protocol 2 port 10 closed
 domain-name TechPubs
 hessid 00-23-68-88-0D-A7
 3gpp mcc 310 mnc 970
 3gpp mcc 505 mnc 14
Related Commands
no
Removes the IP address type configured for this passpoint policy
