privileged-exec-commands
The following table summarizes the PRIV EXEC configuration mode commands:
Privileged Exec Commands
Command
Description
archive
Manages file archive operations
boot
Specifies the boot partition as primary or secondary. The device boots using the image stored in the specified partition.
captive-portal-page-upload (user and privi exec modes)
Uploads captive portal advanced pages to adopted access points
cd
Changes the current directory
change-passwd (user and privi exec modes)
Changes the password of the currently logged-in user
clear (user and privi exec modes)
Clears parameters, cache entries, table entries, and other similar entries
clock (user and privi exec modes)
Configures the system clock
cluster (user and privi exec modes) Initiates a cluster context
configure
Enters the global configuration mode
connect (user and privi exec modes)
Begins a console connection to a remote device
copy
cpe (privilege-exec-mode) Enables adopted T5 CPE (Customer Premises Equipment) device(s) management. Use this command to perform the following operations on the CPEs: boot, reload, upgrade. This command is specific to the RFS 4000, NX 95XX, and NX 96XX devices.
create-cluster (user and privi exec modes)
Creates a new cluster on a specified device
crypto (user and privi exec modes)
Enables encryption
crypto-cmp-cert-policy (user and privi exec modes) Triggers a CMP certificate update on a specified device or devices
database (user and privi exec modes) Enables automatic repairing (vacuuming) and dropping of databases (Captive-portal and NSight)
database-backup (user and privi exec modes) Backs up captive-portal and/or NSight database to a specified location and file on an FTP or SFTP server
database-backup (user and privi exec modes) Restores a previously exported database [captive-portal and/or NSight]. Previously exported databases (backed up to a specified FTP or SFTP server) are restored to the original database.
delete
Deletes a specified file from the system
device-upgrade (user and privi exec modes)
Configures device firmware upgrade parameters
diff
Displays the differences between two files
dir
Displays the list of files on a file system
disable
Disables the privileged mode command set
edit
Edits a text file
enable
Turns on (enables) the privileged mode commands set
erase
Erases a file system
ex3500 Enables the EX3500 switch firmware management. Use this command to perform the following operations: boot, copy, delete, and IP related configurations.
factory-reset Erases startup configuration on a specified device or all devices within a specified RF Domain
file-sync (user and privi exec modes) Configures parameters enabling syncing of PKCS#12 and wireless-bridge certificate between the staging-controller and adopted access points
gps (user and privi exec modes)
Triggers the GPS hardware, on a device, to start/stop search for the device's GPS coordinates.
Note:
This feature is supported only on the AP7662 model access point.
halt
Halts a device (access point, wireless controller, or service platform)
join-cluster (user and privi exec modes)
Adds a device (access point, wireless controller, or service platform), as cluster member, to an existing cluster of devices
l2tpv3 (user and privi exec modes)
Establishes or brings down L2TPV3 tunnels
logging (user and privi exec modes)
Modifies message logging parameters
mint (user and privi exec modes)
Configures MiNT protocols
mkdir
Creates a new directory in the file system
more
Displays the contents of a file
on (user and privi exec modes)
Reverts a command or sets values to their default
on (user and privi exec modes) Executes the following commands in the RF Domain context: clrscr, do, end, exit, help, service, and show
opendns (user and privi exec modes) Connects to the OpenDNS site using OpenDNS registered credentials (username, password) OR OpenDNS API token to fetch the OpenDNS device_id. This command is a part of the process integrating access points, controllers, and service platforms with OpenDNS.
page (user and privi exec modes)
Toggles a device‘s (access point, wireless controller, or service platform) paging function
ping (user and privi exec modes)
Sends ICMP echo messages to a user-specified location
ping6 (user and privi exec modes)
Sends ICMPv6 echo messages to a user-specified location
pwd
Displays the current directory
re-elect
Re-elects the tunnel controller (wireless controller, service platform, or access point)
reload
Halts a device (wireless controller, service platform, or access point) and performs a warm reboot
rename
Renames a file in the existing file system
rmdir
Deletes an existing file from the file system
self
Displays the configuration context of the device
ssh (user and privi exec modes)
Connects to another device using a secure shell
t5 (privi exec mode) Executes the following operations on a T5 device: copy, rename, delete, and write. This command is specific to the RFS 4000, NX 95XX and NX 96XX devices.
telnet (user and privi exec modes)
Opens a Telnet session
terminal (user and privi exec modes)
Sets the length and width of the terminal window
time-it (user and privi exec modes)
Verifies the time taken by a particular command between request and response
traceroute (user-privi-exec-mode)
Traces the route to a defined IPv4 destination
traceroute6 (user-privi-exec-mode)
Traces the route to a defined IPv6 destination
upgrade
Upgrades the software image
upgrade-abort
Aborts an ongoing software image upgrade
exit (privi exec mode) Ends the current CLI session and closes the session window
watch
Repeats the specific CLI command at a periodic interval
virtual-machine (user and privi exec modes)
Installs, configures, and monitors the status of VMs. This command is specific to the NX 95XX and NX 96XX series service platforms.
raid
Enables RAID management. This command is specific to the NX 95XX and NX 96XX series service platforms.
For information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see COMMON COMMANDS.
The input parameter <HOSTNAME>, if used in syntaxes across this chapter, cannot include an underscore (_) character.
