Configure Flow-Based Mirroring in a Multi-Tenant Architecture
  1. Run the following commands to configure access control list applications on ethernet or port channel and VLAN or virtual ethernet:
    efa tenant epg create --name <epg-name> --tenant <tenant-name>
                     --switchport --switchport-mode trunk –ctag-range <ctag-range>
                     --port <mirror-source-port-list> --po <mirror-source-po-list>
                     --pp-mac-acl-in <acl-name> --pp-mac-acl-out <acl-name>
                     --pp-acl-in <acl-name> --pp-ip-acl-out <acl-name>
                     --np-mac-acl-in <ctag:acl-name> --np-mac-acl-out <ctag:acl-name>
                     --np-ip-acl-in <ctag:acl-name> --np-ip-acl-out <ctag:acl-name>
  2. Run the following commands to configure a mirror session:
    efa tenant service mirror session create –name? <session-name> --tenant <tenant-name>
                        --source {<device-ip>,<eth | po | vlan>,<if-name>}
                        --type {<source-device-ip>,<eth | po | vlan>,<source-if-name>:<port-based | flow-based>}
    	             --destination {<source-device-ip>,<eth | po | vlan>,<source-if-name> :
    		        	<destination-device-ip>,<eth | po | vlan>,<destination-if-name}
                        --destination-type {<source-device-ip>,< eth | po | vlan>,<source-if-name>:<span>}
                        --direction {<source-device-ip>,< eth | po | vlan>,<source-if-name> : <tx | rx | both>}
    (efa:root)root@node-2:~# efa tenant show
    |     Name     |  Type   | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD |         Ports         |  Mirroring Ports    |
    | sharedTenant | shared  |            |             |             |     0     |   false   |                       | 10.20.246.15[0/31]  |
    |              |         |            |             |             |           |           |                       | 10.20.246.16[0/31]  |
    |              |         |            |             |             |           |           |                       | 10.20.246.21[0/31]  |
    |              |         |            |             |             |           |           |                       | 10.20.246.22[0/31]  |
    |              |         |            |             |             |           |           |                       | 10.20.246.25[0/31]  |
    |              |         |            |             |             |           |           |                       | 10.20.246.26[0/31]  |
    |     ten1     | private |   11-20    |             |             |    10     |   false   | 10.20.246.15[0/1-10]  |                     |
    |              |         |            |             |             |           |           | 10.20.246.16[0/1-10]  |                     |
    |     ten2     | private |   21-30    |             |             |    10     |   false   | 10.20.246.15[0/11-20] |                     |
    |              |         |            |             |             |           |           | 10.20.246.16[0/11-20] |                     |
    (efa:root)root@node 2:~# efa tenant po show
    |   Name  | Tenant | ID |  Speed  | MTU | Negotiation | Min Link |  Lacp   |        Ports      |    State   |  Dev State  |  App State  |
    |         |        |    |         |     |             |   Count  | Timeout |                   |            |             |             |
    | ten1po1 | ten1   |  2 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/1] | po-created | provisioned | cfg-in-sync |
    |         |        |    |         |     |             |          |         | 10.20.246.16[0/1] |            |             |             |
    | ten2po1 | ten2   |  3 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/11]| po-created | provisioned | cfg-in-sync |
    |         |        |    |         |     |             |          |         | 10.20.246.16[0/11]|            |             |             |
    efa tenant epg create –name ten1epg1 –tenant ten1
                --switchport-mode trunk --po ten1po1 --ctag-range 11
                --pp-ip-acl-in ext-ip-permit-any-mirror-acl
                --pp-ip-acl-out  ext-ip-permit-any-mirror-acl
    efa tenant service mirror session create –name ten1mirrorsession1 --tenant ten1
                --source 10.20.246.15,po,ten1po1
                --type 10.20.246.15,po,ten1po1:flow-based
                --destination 10.20.246.15,po,ten1po1:10.20.246.15,eth,0/31
                --destination-type 10.20.246.15,po,ten1po1:span
                --direction 10.20.246.15,po,ten1po1:both
    efa tenant service mirror session create –name ten2mirrorsession1 --tenant ten2
                --source 10.20.246.15,po,ten2po1
                --type 10.20.246.15,po,ten2po1:flow-based
                --destination 10.20.246.15,po,ten2po1:10.20.246.15,eth,0/31
                --destination-type 10.20.246.15,po,ten2po1:span
                --direction 10.20.246.15,po,ten2po1:both
    efa tenant epg create –name ten2epg1 –tenant ten2
                --switchport-mode trunk --po ten2po1 --ctag-range 21
    efa tenant service mirror session create –name ten1mirrorsession2 --tenant ten1
                --source 10.20.246.16,po,ten1po1
                --type 10.20.246.16,po,ten1po1:flow-based
                --destination 10.20.246.16,po,ten1po1:10.20.246.16,eth,0/31
                --destination-type 10.20.246.16,po,ten1po1:span
                --direction 10.20.246.16,po,ten1po1:both
    efa tenant service mirror session create –name ten2mirrorsession2 --tenant ten2
                --source 10.20.246.16,po,ten2po1
                --type 10.20.246.16,po,ten2po1:flow-based
                --destination 10.20.246.16,po,ten2po1:10.20.246.16,eth,0/31
                --destination-type 10.20.246.16,po,ten2po1:span
                --direction 10.20.246.16,po,ten2po1:both
  3. Verify the switch configuration on the SLX device.
    10.20.246.15
    SLX# show running-config ip access-list
    ip access-list extended ext-ip-permit-any-mirror-acl
     seq 10 permit ip any any mirror
    SLX# show running-config interface Port-channel 2,3
     description EFA Port-channel ten1po1
     cluster-client auto
     switchport
     switchport mode trunk
     switchport trunk allowed vlan add 11
     no switchport trunk tag native-vlan
     ip access-group ext-ip-permit-any-mirror-acl in
     ip access-group ext-ip-permit-any-mirror-acl out
     no shutdown
    interface Port-channel 3
     description EFA Port-channel ten2po1
     cluster-client auto
     switchport
     switchport trunk allowed vlan add 21
     no shutdown
    SLX#
    10.20.246.16
     cluster-client auto
     switchport
     no shutdown
     cluster-client auto
     switchport
     no shutdown
    SLX#
    10.20.246.15
    SLX# show running-config monitor session
    monitor session 1
     source port-channel 2 destination ethernet 0/31 direction both
    !monitor session 2
     source port-channel 3 destination ethernet 0/31 direction both
    SLX# show monitor session 1
    Session                : 1
    Type                   : SPAN
    Description            : [None]
    State                  : Enabled
    Source Interface       : Po 2 (Down)
    Destination Interface  : Eth 0/31 (Down)
    Direction              : Both
    Type                   : flow-based
    SLX# show monitor session 2
    Session                : 2
    Type                   : SPAN
    State                  : Enabled
    Source Interface       : Po 3 (Down)
    Direction              : Both
    Type                   : flow-based
    10.20.246.16
    monitor session 1
    !monitor session 2
    Session                : 1
    Type                   : SPAN
    State                  : Enabled
    Direction              : Both
    Type                   : flow-based
    Session                : 2
    Type                   : SPAN
    State                  : Enabled
    Direction              : Both
    Type                   : flow-based
