Configure remove-private-as on BGP Peer
  1. Run the following command to create a BGP Peer on a tenant VRF:
    efa tenant service bgp peer create --name <bgp-peer-name> --tenant <tenant-name>
                       	--ipv4-uc-nbr <device-ip,vrf-name:neighbor-ip,remote-asn>
                       	--ipv4-uc-nbr-bfd <device-ip,vrf-name:neighbor-ip,true|false>
                       	--ipv4-uc-nbr-remove-private-as <device-ip,vrf-name:neighbor-ip,true|false>
  2. Run the following command to update a BGP Peer on a tenant VRF:
    efa tenant service bgp peer update --name <bgp-peer-name> --tenant <tenant-name>
                 --operation peer-add
                 --ipv4-uc-nbr 10.20.246.25,v1:10.20.30.50,50000
    		--ipv4-uc-nbr-bfd 10.20.246.25,v1:10.20.30.50,true
    		--ipv4-uc-nbr-remove-private-as 10.20.246.25,v1:10.20.30.50,true
    		--ipv4-uc-nbr 10.20.246.26,v1:10.20.30.50,50000
    		--ipv4-uc-nbr-bfd 10.20.246.26,v1:10.20.30.50,true
    		--ipv4-uc-nbr-remove-private-as 10.20.246.26,v1:10.20.30.50,false
    Example:
    efa tenant service bgp peer create --name ten1bgppeer1 --tenant tenant11
    		--ipv4-uc-nbr 10.20.246.25,v1:10.20.30.40,50000
    		--ipv4-uc-nbr-bfd 10.20.246.25,v1:10.20.30.40,true
    		--ipv4-uc-nbr-remove-private-as 10.20.246.25,v1:10.20.30.40,true
    		--ipv4-uc-nbr 10.20.246.26,v1:10.20.30.40,50000
    		--ipv4-uc-nbr-bfd 10.20.246.26,v1:10.20.30.40,true
    		--ipv4-uc-nbr-remove-private-as 10.20.246.26,v1:10.20.30.40,true
    10.20.246.25
    ORCA_01# show running-config router bgp
    address-family ipv4 unicast vrf v1
      redistribute connected
      neighbor 10.20.30.40 remote-as 50000
      neighbor 10.20.30.40 remove-private-as
      neighbor 10.20.30.40 bfd
      neighbor 10.40.40.253 remote-as 4200000000
      neighbor 10.40.40.253 next-hop-self
      maximum-paths 8
    10.20.246.26
    ORCA_02# show running-config router bgp
      neighbor 10.40.40.252 remote-as 4200000000
      neighbor 10.40.40.252 next-hop-self
      maximum-paths 8
    efa tenant service bgp peer show --detail
    Tenant           : tenant11
    State            : bgp-peer-created
    Description      :
    Static Peer
    Device IP                   : 10.20.246.25
    VRF                         : v1
    AFI                         : ipv4
    SAFI                        : unicast
    Remote IP                   : 10.20.30.40
    Remote ASN                  : 50000
    Next Hop Self               : false
    Update Source IP            :
    BFD Enabled                 : true
    BFD Interval                : 0
    BFD Rx                      : 0
    BFD Multiplier              : 0
    MD5 Password                :
    Remove Private AS           : true
    Default Originate           : false
    Default Originate Route Map :
    Prefix List In              :
    Prefix List Out             :
    Route Map In                :
    Route Map Out               :
    Dev State                   : provisioned
    App State                   : cfg-in-sync
    VRF                         : v1
    AFI                         : ipv4
    SAFI                        : unicast
    Remote IP                   : 10.20.30.50
    Remote ASN                  : 50000
    Update Source IP            :
    BFD Enabled                 : true
    BFD Interval                : 0
    BFD Rx                      : 0
    BFD Multiplier              : 0
    MD5 Password                :
    Prefix List In              :
    Prefix List Out             :
    Route Map In                :
    Route Map Out               :
    Device IP                   : 10.20.246.26
    VRF                         : v1
    AFI                         : ipv4
    SAFI                        : unicast
    Remote ASN                  : 50000
    Update Source IP            :
    BFD Enabled                 : true
    BFD Interval                : 0
    BFD Rx                      : 0
    BFD Multiplier              : 0
    MD5 Password                :
    Remove Private AS           : false
    Prefix List In              :
    Prefix List Out             :
    Route Map In                :
    Route Map Out               :
    VRF                         : v1
    AFI                         : ipv4
    SAFI                        : unicast
    Remote ASN                  : 50000
    Update Source IP            :
    BFD Enabled                 : true
    BFD Interval                : 0
    BFD Rx                      : 0
    BFD Multiplier              : 0
    MD5 Password                :
    Prefix List In              :
    Prefix List Out             :
    Route Map In                :
    Route Map Out               :
  3. Verify the switch configuration on the SLX device.
    Rack1-Device1# show running-config router bgp
    router bgp
     local-as 4200000000
     capability as4-enable
     fast-external-fallover
     neighbor 10.20.20.4 remote-as 4200000000
     neighbor 10.20.20.4 next-hop-self
      network 172.31.254.46/32
      network 172.31.254.123/32
      maximum-paths 8
      graceful-restart
     address-family ipv4 unicast vrf ten1vrf1
      neighbor 10.20.30.50 remote-as 50000
      neighbor 10.20.30.50 remove-private-as
      neighbor 10.20.30.50 bfd
      maximum-paths 8
     address-family ipv6 unicast
     address-family ipv6 unicast vrf ten1vrf1
      maximum-paths 8
     address-family l2vpn evpn
      graceful-restart
    Rack1-Device2# show running-config router bgp
    router bgp
     local-as 4200000000
     neighbor 10.20.20.5 remote-as 4200000000
     neighbor 10.20.20.5 next-hop-self
      network 172.31.254.176/32
      maximum-paths 8
      graceful-restart
      maximum-paths 8
      maximum-paths 8
      graceful-restart
    For information about commands and supported parameters to configure remove-private-as attribute, see Extreme Fabric Automation Command Reference, 2.7.0 .
