Device Certificates
The HTTPS server certificate from EFA is presented to a client when that client connects to its northbound interface.
During the registration of an SLX device in EFA, the following configuration changes are made on the device.
You can use the efa inventory device list command to verify the status of the certificates on the device. If the Cert/Key Saved column contains "N," then certificates are not installed.
You can use the efa certificates device install --ips <ip-adddr> certType [ http|token] command to install the HTTPS or OAuth2 certificate on one or more devices.
