Configure Listen Limit on BGP Dynamic Peer
EFA enables configuration of global router BGP listen-limit which depends on the router BGP dynamic peer scale requirements. Listen-limit configuration defined under the “global router bgp” context signifies the maximum number of dynamic BGP peers that can be operational across the VRFs in the SLX. Default value of the global router BGP listen-limit is 100, which you can modify with any value in the range of 1-2400.
  • For the SLX version 20.3.4 or lower, the supported listen-limit range is <1-1024>.
  • For the SLX version 20.4.1 or higher, the supported listen-limit range is <1-2400>.
Ensure that the listen-limit configuration defined at the “dynamic peer listen-range” level is less than or equal to the “listen-limit” configuration defined under the “global router bgp”. Pre-2.5.0 versions of EFA do not support configuration of global router bgp listen-limit.
The maximum number of dynamic BGP peers is limited to the SLX default (100), when provisioned through EFA.
Configure the new fabric setting for each fabric with bgp-dynamic-peer-listen-limit command. The fabric setting is applicable for Clos and small data center fabrics, and for all types of devices (leaf, border-leaf, spine, super-spine).
Configure the bgp-dynamic-peer-listen-limit value on all the devices of the fabric when you configure the fabric.
You can configure the bgp-dynamic-peer-listen-limit on an already provisioned fabric. For the new value to be effective, run the fabric configure command, followed by the efa fabric setting update command. This enables you to configure bgp-dynamic-peer-listen-limit on the existing pre-2.5.0 deployments.
You can only increase (but not decrease) the value of bgp-dynamic-peer-listen-limit on an already provisioned fabric.
  1. Run the following command:
    efa fabric setting update –name <fabric-name> --bgp-dynamic-peer-listen-limit <1-2400>
  2. Verify the switch configuration on the SLX device.
    Rack1-Device1# show running-config router bgp
    router bgp
     local-as 4200000000
     capability as4-enable
     fast-external-fallover
     listen-limit 200
     neighbor 10.20.20.5 remote-as 4200000000
     neighbor 10.20.20.5 next-hop-self
     address-family ipv4 unicast
      network 172.31.254.139/32
      network 172.31.254.226/32
      maximum-paths 8
      graceful-restart
     address-family ipv6 unicast
     address-family l2vpn evpn
      graceful-restart
    Rack1-Device2# show running-config router bgp
    router bgp
     local-as 4200000000
     listen-limit 200
     neighbor 10.20.20.4 remote-as 4200000000
     neighbor 10.20.20.4 next-hop-self
      network 172.31.254.115/32
      maximum-paths 8
      graceful-restart
      graceful-restart
